Discuss New loo on 3 inch soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Morning all. I hope you are well. Pretty sure I have asked this before but cannot remember.
I am installing a new toilet but have discovered where the soil pipe needs to go there is only 3 and a bit inches diameter. Either side are gas pipes and cables. Is it possible to go from a 3 inch flexible multikwik to a 4 inch soil pipe?
Cheers
There do a special extension from multi one end 3" the other 4"
I was going to put thanks Shaun at the end of the thread.
But is it ok to go from the pan connector in into a 3 inch to 4 inch adaptor about 500mm away?
Lol
Yes I think if you look at maclpine they do a 3" pan connector (to normal toilet)
Lol
I also think viva slinky come with 2 different size thins on their flexible connectors.
It needs to be a flexi really otherwise I will have to buy some 3 inch soil pipe which I hear is expensive!
? How far short are you ?
I
Have a 4 inch pipe in the wall, then right in front of that I have a gas meter on the left and a barrel gas pipe on the right. The gap between these is just over 3 inches. This is to the right of the back of the pan which is around 450mm
soil needs to be 4in or it may be prone to blockages !
www.blockeddrainsbirmingham.co.uk
It is true. Although some old pipes were 3 inch I believe. The custard has actually said the toilet is just for peeing as it is off the main hall. I think I shall give them the option to get the meter moved or si k with a 3 inch and get them to sign a bit of paper agreeing to the 3 inch pipe and possible blockages
So chaps another question. I need to cut a tee into this cast iron soil pipe. Do i need to replace the whole lot in plastic or will a couple of fernco's and a bit plastic do the trick as it is clipped pretty securely most of the way up.
Cut a 110mm tee in ?
Meant to say spigot top and bottom but it doesn't look like there is. So 2 fernco's, 1 tee and a bit of pipe to put into the top of the tee.
I wouldn't I would replace the lot
Could you not use a timesaver cast tee ? that what i have done in the past . cheers kop
Now that would could work a treat but worried that the cast wouldn't really have any support at the bottom.
How flexible are they as with using
It would be nice but I am thinking these are very expensive. Look the part though
Saint gobin bud drainage centre keep it part of the wolsey group hardest bit is cutting a section of pipe out . cheers kop
Yes you will need 3 collars to suit your pipe they are retail prices so depending on your discount its cheaper than replacing the whole stack and less damage to the property , i just use a 9" grinder with a metal cutting disc no particular make. Cheers kop
They do a support collar if your worried but i think you would be fine its how i would do it cast tee then black 110mm out the branch , no.way i would take the stack down . kop
I'd replace the stack if it was a south-facing wall and in the summer. Did one last year and I got more of a tan than a week in Ibiza!!
Yes but could I do it with the fernco T or plastic T. I won't be able to get a cast one today and ideally would like to finish. The out side diameter if cast is 111mm. Is that a standard 100mm cast fitting required
Speaking from experience i would use the timersaver anything else wont look right Fernco no i wouldnt, 100mm will fit its measured internal just get the right collars a days work , changing the stack a weeks work a tower needed in poor weather no way £1000 at least you know it makes sense get the timesaver . kop
Does the standard coupling go from cast iron to plastic?
Reply to New loo on 3 inch soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
