Discuss New member Paul, dripping Franke Olympus Triflow tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Paul Hine
Hi all,
The above hardware has forced my entry into your murky plumbing cabal !
My tap is dripping (on the hot water side of triflow) and I would like to inspect the cartridge.
I have looked at the schematic on Franke's website which clearly shows hidden grub screws to remove the tap levers......my taps have none.....I've looked everywhere. I can remove the levers from the main body that turns but cannot work out what I might try next to get to the cartridges, any sage suggestions much appreciated.
Cheers
Paul
Hi Paul. Welcome to the forum.
This post should really have been posted under the Valves and Taps or Plumbing sections of this forum.
I have struggled with a few different versions of Franke Olympus mixers to remove the levers. Some drawings show grub screws, but not all have them and drawing may not relate to your exact model. I don't want to say how I discovered to remove handles on 2 different types of Olympus mixers, as yours could be different and risk of damage.
When you do go to put it all together, use some Vaseline or silicone grease on any meeting parts that might seize later.
Try this instruction to see if same as yours and let us know, -
http://www.frankefilterflow.co.uk/media//product_custom_files/t/r/triflow_olympus_2.pdf
Apologies for posting in the wrong place, I got a little excited with my introduction.
The link was bang on, I removed the valve, disassembled and cleaned it but the leak was still present when I fixed it back so I will find the correct part and order it.
Thanks for your prompt help.
Regards
Paul
You normally need to replace any faulty cartridge that causes tap to drip.
If you push against a handle, forcing it against the tap body, you might find the drip lessens or stops, which indicates that cartridge is faulty.
Central Services (Franke spares) will supply any parts you need, but expensive in my opinion now. About ÂŁ20 inc vat there.
Franke don't half charge you for spares, I had cause to contact them a few weeks ago for a tap valve and they wanted my first born as payment ;)
I ended up using tap magician who were pretty good, still expensive but not like Franke.
These are the valves you will need, I'd go for the pack of 3 and replace all of them at once if I were you because if one has failed then the others are probably not far behind.
The Tap Magician
Welcome to the depths :D
Reply to New member Paul, dripping Franke Olympus Triflow tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
Need to remove the spout on a Franke Olympus tap. I have removed the hot/cold previously with an allen key and the spout kit has a 2.5mm allen key in the pack. However, I can't get the allen key to take. It feels like the grub screw may be missing but the replacement grub screw won't go in. I'm...
Bob Hope
Hi, I am a new member and looking for advice to access and remove a tap cartridge from my bath. I have a dripping bath tap which is driving me crazy. I can't see how to remove the cartridge to replace it and looking for any advice from anyone who has similar taps. I can obviously see the grub...
1K
Deleted member 120897
Hi, my 2-handle kitchen mixer tap started dripping cold water. I've got it apart and am waiting for a new cold water, ceramic disc, 1/4 turn, cartridge to be delivered. Meanwhile I can't completely turn off the isolating (or service) valve, whose screwdriver slot is now knackered. So, with tap...
My Franke Eiger mixer tap started leaking from where the spout joins the body. I took the spout off, the o rings looked ok so I put a bit of silicone grease on and put it back. After a couple of days it started again. I have a friend that has about six different boxes of o rings, he must have...
1K
