Discuss New Radiator pipe work advice needed please.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, not sure if this is in quite the correct section - but here goes!!!
Iam looking for some advice regarding new pipe work to rads which i have recently fitted to the wall. the walls are brick. The flooring is suspended wooden and i can get the floor up easily and have good access to existing heating pipes from previous radiators situated in the room.
My issues are: would it be best to just go straight down through the floor boards and connect up the rads or is it worth trying to chase the pipe work into the walls under neath the rads??
any help or advice greatly recieved... thanks adam
Depends on the finish you wish to achieve. Chasing in is more work, but you get clean lines. Pipes in floor catch dust and are difficult to hoover around. Make sure the rad valves are still fitted upwards as you don’t want them sticking into the room, biting people’s ankles.
Whichever you choose, you won't notice it after a week.
Try a mock up of each style using a valve and and short length of pipe cut to length so it looks like the finished work will without actually being plumbed in.
The first pic looks like the rad will need moving over slightly to the right.
Normal practice is to run the pipework under the floor boards and feed the radiators with pipework straight up into the rad valves . cheers kop
I would go straight down into the floor, if you don't like the look of copper pipe you can do it in chrome pipe
Yes, straight down through the floorboards is the most common and practical way to do it in my opinion.
Reply to New Radiator pipe work advice needed please.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind toilet. There's a concrete patio outside the bathroom, that extends about 10 feet from the wall. I'm considering adding an ADU in the back yard, and it...
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at rear of new extension for sink waste clean water pipe carry out 2 x Lead connections with a new T section No excavation needed, all is digged out.
Hi All, I'd like to install new radiators in my home which are currently fed by copper pipe via the floor boards. I live in a bungalow and access beneath floorboards is quite good access. I'd like to change the piping to come out the walls instead and therefore looking to use speedfit products...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
