Discuss new waste connection for toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I need to know which fitting to use for the soil pipe to make a new waste connection to the toilet. The new location will be 12inches to the left of the current one.
thats a good one, as its glued fittings you would need to cut where the red lines (approx) and use two couplings and re pipe
Thanks for the fast reply. That's exactly what I needed.
I'll post a picture when it's done, though it might take a while.
may i ask why your removing / moving the existing toilet ? (bathroom update?)
why a 3m pipe and not just a 1m?
The previous owners changed the bathroom horrendously. All the pipes are visible and there's much less space now. What I'm doing now is just restoring it to how it should have been all along.
if you can get a 1m piece go for that most places in the trade only sell 3m +
Reply to new waste connection for toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
