M
Milomouse
Hi
Next door's flue is making a scary gurgling and popping noise - they're away for Easter so we can't go round, does it sound dangerous to any of you professionals?
Thanks Hilary
Discuss Next door's flue is making a gurgling noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yeah Shaun has enlightened me cheers snowheadMe also.
CH4,,NOT running.
Anything they can do or anybody they can ring in the meantime?I know what it is
And no will just lockout but needs sorting
Needs a service and a clean as soon as they get back
So it's not dangerous? The property isn't rented it's owned by next door but as they're are away and we're semi-attached to them I'm a little worried as every time their boiler ignites the noise is getting worse
Thanks Hilary
Good thinking batman!Turn the gas off at their meter box the boiler will lockout and fail safe if its worrying you that much
Sounds like the condensate is backing up into the heat exchanger.
Hi
Thanks Hilary
Completely agreeSounds like the condensate is backing up into the heat exchanger.
Reply to Next door's flue is making a gurgling noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
