Discuss no FSDs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
commercial kitchen has an old burner with no FSDs, presently its possible to turn the gas on and walk away without lighting it
needs a new piperun with an interlock,
obviously its advisable but does it also have a low pressure cut off or some sort of pressure proving device
cant recall whats the legal minimum was
one of the chiefs must have lent on the oven control knob while cleaning, filled the oven with gas which subsequently went bang and blow the doors open when she lighted the hob
Yes! Low pressure sensor with interlock to solenoid valve and interlock with ventilation extraction system is what you need. Similar scenario to chemistry labs in educational establishments.
thanks Reg,
I knew about the extract just couldnt remember if the low pressure sensor was mandatory
Reply to no FSDs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
Hi all, I'm going to be getting my cookers ticket soon and I'm a little confused on the classification for faults. If I turn a gas oven on and its starts on high flame what would this be classed as? Also for things such as fsds on hob burners I am assuming that if it doesnt keep the burner lit...
Condensing boiler installed by local Gas Safe plumber in 2014, not combi. Failed a couple of weeks ago with flashing blue light which googling suggests means no gas, blocked flue or blocked condensate pipe. There is gas, the flue is clear, and the condensate pipe goes into the under-sink waste...
4K
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the existing boiler needed upgrading. The Mechanical Engineers advising the architect insisted that we had a conventional cast iron combustion chamber boiler...
1K
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe (3 soldered joints only) running into house to the kitchen, to gas hob (with another isolator just prior to hob). System Failing tightness test...
2K
