Discuss Not paying for a job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have spoken with Citizens advice, they have said:
I could pay the invoice in full under protest to stop any court proceedings then try and claim back part of the money once it's fixed.
Or I can pay for materials only.
Or I should keep up communication with him, until such time as the faults have been rectified by him or another trades person and come to a mutual agreement.
I'm thinking that his materials minus the cost of what has been damaged or needs replacing, i.e. having to re-tile the bathroom so new tiles, damaged pipe to bath filler etc and then paying the balance. he wouldn't end up with much.
Not sure I want a court battle but CA said you have a strong position as you have let him try and fix it 6 times and photographic evidence, but they advise that it's better to come to a mutual agreement than drag it through court.
So pretty much said what most people on here have said. It's christmas now so nothing is going to get done until the new year, I'm looking at shower panels as a replacement to the tiles if that is the issue, but will have to be guided by another trades person, so I'll have to start my hunt for one in January.
__________________
I will bet santa coming tonight that there is, put a post in the I am looking for a plumber forum
Do not part with any money at this stage. Before court action, claimant must send, "letter before action" giving you notice and time to pay. On receipt of such letter, respond, recording his 6 failed attempts to rectify the problems and notification that should he proceed with action through the courts, you will counter claim for the full cost of all remedial work, together with your direct and consequential losses.
Another rushed bodged bathroom. Total and unequivocal rip out and redo.
Don't pay him his labour, he made the decision not to get paid by rushing and bodging. Look at the state of those tile trim mitres.
I say mitres, he hasn't even bothered!
It's rough indeed. I think, though, he'd have got away with it if it only hadn't leaked. To smear more silicone on top of old and leave it that rough is not excuseable - there is no reason not to make it look neat.
I wonder whether the plumber has developed dementia or something - this does not look like even an experienced DIYers work. Or he has no experience whatsoever.
Stramitt board is awful stuff to tile to, but it can be done.
Mix powdered flexii adhesive with a water and SBR mix (like a slurry) apply a thin coat, ike plaster. When dry tile as normal.
I've come across it once but never tiled to it, I don't think I'd dare for fear of problems. What is the idea of this board? How old is the stuff? does it pre date plasterboard?
Easy to put up like the cardboard walls and didmt require much structure but you have to be careful as some did contain ab
from what ive read, looks like the walls should of been stripped off to the bare stud work and wedi boarded, tiles don't just come loose and no amount of silicone will fix that, IMO its his fault for tiling on top of crap, he could argue the price in that no allowance was made for that but you wouldn't build a house on crap foundations and if you did then it would still be your fault! bathrooms aren't cheap and you certainly don't want to cut corners as you have found out, even though the o.p didn't cut corners as he probably thought it was all being taken care of professionally! sucks but IMO It all needs stripping out...
Is this stuff attached to studwork? or is it some kind of prefabricated eggbox and straw wall?
If it can be simply ripped back to studwork I cant understand why he didn't do this.
it's rubbish work but i see every bit as bad work every day. if it hadn't leaked and the tiles had stayed put for 12 months he'd have probably got away with it as it would have just been "bad finishing."
the flexi is fit to burst but there are currently 50 billion out there in the same condition happily biding their time. i change one that burst this morning. bank holiday monday call out thank you very much what what.
not may studs/ timbers they come in i think 8 foot by 4 panels so every 4 foot theres a timber
Definitely rip out. but possibly not all.
Get some proper quotes, you may only have to replace a few rows of tiles.
Seems odd to me to silicon inside and outside of shower enclosure.
flexi's will definitely have to be replaced.
IMO, you should compromise on materials, NOT labour. Move on, get several quotes and start a new year on a positive note
Oh dear. It's all been said earlier but here are a couple of tips and hints for the future. And for my 2 cents worth: you will never make that job any good without ripping it out and starting from scratch. You will never make that mess look good. Personally I detest poly wall panel I think it looks poor and I hate working with it.
With the amount of water leaked into the walls and floor it will take some time to dry out. And it must be dry before further work is started. I have only come across a similar material once before and due to a slow leak from a cwt the wall actually started to grow, swell, and sprouted. It was made from hay I believe. Judging by the black mould in the video, is this leak new or just worse?
Check to see if a fitter has a public liability insurance that covers the trades that you are paying for. If not then do not use him. If he has then you can claim against his insurance to have the work done again due to the damage he has caused.
Also some PLI have what's known as an efficacy clause. This insurers for bad workmanship.
Did you get a Building Reg Prt P cert from the electrician? If not then chase him up for it. He has a limited time to register your work. If he is not part of the self cert scheme you will need to get building controls in to cert the work. Average cost in the UK is £150 to £350 for that. Legally You will need that cert if you sell the property.
Check to see that the aqualisa shower was fitted as per manufacturers exact spec. If not the 5 year warranty will be invalid. As a retired aqualisa approved installer I can tell you they are getting much stricter with that. BTW the aqualisa web site is a good place to find an approved bathroom installer.
Consider making a claim on your buildings insurance for the water damage if your installer does not have a valid PLI. You may recover all your costs that way.
Normally I tend to side with the tradesman in these disputes but if everything you have told us is the truth and you would need to swear to that in court, then I think you have been badly done by. If you do go to court you are entitled to legal representation, the cost of which is reclaimable. Most house insurance has that thrown in anyway.
I would not entertain any further visits from your man.
If it was me coming to sort that out then it would be getting taken out, cleaned up the fitted back in properly. That would be the only option id offer
There was a leak originally which was why we looked at getting a whole new bathroom. We advised all fitters of this when they came round, and pointed out the issues plus the type of walls they were dealing with.
I didn't check these, how do I find out if they have insurance? or is this only done by contacting them and requesting it?
I have checked this, the job has been registered so I have been told.
I have been looking round for trades today to come in and quote for the remedial work, I have asked them to check all aspects of the plumbing work, separately I have been looking for a tiler via the checkatrade website hopefully they can advise on what needs to be done.
Thank you for your advice, never thought about Buildings Insurance claim, I will see what the cost of the work will come to, and make a decision from their.
What I have put is the truth, I thought this site would be full or trades people that will just back each other, but I wanted to get some advice from proper trades people on which way I should take this, and everyone has given useful advice, and things I hadn't thought of. Ripping out and starting again isn't something I really relish, but if that's how it gets sorted properly, then that's the way it will have to be.
Just hope second time round it will all work out.
If you do need evidence of bad workmanship for court, take plenty of photographs at all stages of removal and also get reports from experts (qualified plumbers and other trades).
Courts won't just accept your word
Don't use checkatrade for references, ask your neighbours if they have had any work. Or know anyone. Personal recommendation is always best.
Ask the new guy for examples of his work and contact those customers to confirm!
You won't offend, I get asked for pictures of my work on bathrooms all the time.
What's wrong with Checkatrade? I'm on I don't bodge things, rip people off leave leaks (or if I do by mistake I sort it)
All I'm saying is the best way of checking someone's work is to see it.
I agree but unless you take people round to jobs that you have done how do they know that's your work off photos and not something you have pinched off the internet?
You should receive a form from the electrician which is a self certification form issued by one of the only two bodies in the UK legally authorised to do so. NIECC AND NAPPI. The tradesman has to submit this form to the organisation and a few weeks later you will get a cert from building control. The trade has to give you that paperwork. If they don't you need to report this to building control. They will prosecute.
Ask trades for copies of their insurance. I always supplied one with the estimate, not offended or suspicious if asked. In fact proud to give it, also same for certs of qualifications, references etc etc.
Don't reckon check a trade etc etc. Too easy to fake results imho.
Also imho tilers are tilers. Builders are builders. Word of mouth and personal recommendations are always the best imho. You're local trading standards will have a list of qualified trades. So will building control. Well they do in Hertfordshire anyway.
Sorry to resurrect my thread, but an update on proceedings.
On the 5th Jan I issued a letter to the fitter stating the issues we found, and our intent to withhold payment it was reviewed but other professionals, if the quote for rectification work was under the invoice amount, we would subtract this from the invoice and pay the remainder.
No answer to letter.
We had a family recommended plumber to quote, the shower has all been plumbed incorrectly so warranty is void, pipes not lagged etc. Has quoted for work.
Recommended tiler laughed at pictures of before, said there's 2 choices, Tiler Backer/Aqua panel 12mm put onto wall, and then tiled over or replace wall.
Also have the shower screen manufacturers technician visit to review the shower screen, he noted the amount of silicone, said it had not been fitted correctly, pointed out the thick bead of silicone on the outside was to cover the holes that had been drilled in the tiles where the screen had been incorrectly fitted, and said it's still not fitted correctly.
Total for rectifying work is £1800
Sent follow up letter to fitter stating this, and formally refusing payment. So as not to have this dragging on we have suggested that he can keep the £250 deposit and that is the matter finished with him and allows us to commission the repair work. He has 10 working days to respond of which 5 is over currently. No response as yet.
I did see his van this morning when walking the dog, felt like warning the home owner, but not sure that's my place to do so.
Sounds fair and reasonable - from what you have told us.
You may want to get legal advice to make sure you are acting within the Law.
You may want to get a lawyer to send letters for you.
As for warning the other homeowner about your experiences - don't get involved.
If they ask you, tell them as much as you dare
True, best keep out of it. I just want my situation sorted.
As for the solicitor, I could but it's all additional cost on my side to do that. Ideally he responds accepting the situation, and the agreement is made. I need to tread carefully after 10 days, but checking with the CAB it's best to make an agreement outside of solicitors.
It may be peace of mind for you to have your agreement checked over by a solicitor.
You cannot make an agreement with someone, if that agreement is outside the realms of the Law.
If the Plumber has had your agreement check over by a solicitor, and his solicitor deems it to be outside the Law, you could end up in deep and expensive trouble.
The Law doesn't care about your situation - it only cares about the Law.
If you breach the Law - then the Law will come after you.
I was told that by an ex-judge whom I was working for.
You already have an agreement/contract with the original fitter. What you are seeking is to conclude that agreement by "mutual consent". Having set on record the defects all future correspondence towards settlement should be headed, "WITHOUT PREJUDICE". Be aware that an offer made, without prejudice, if accepted becomes binding.
As there has been no response and no communication to date, I doubt I will get anything in writing accepting the terms. This is why I stated
"We will give you 10 working days from the date of this letter to dispute this offer. Should we not received a formal response to our letters we will take this that you have accepted this offer and the matter will not be taken any further."
Which I'm hoping allows us to finally get this mess sorted! Otherwise with no responses it could drag on for months worth of uncertainty.
What it would come down to is who breached contract first, you for withholding payment or the plumber for not fulfilling the work he was contracted to do. Docs titled Without Prejudice cannot be used as evidence in legal proceedings, nothing to do with contract law. See http://legal-dictionary.thefreedictionary.com/Without+Prejudice. What you are looking at is a Tort. See http://dictionary.law.com/Default.aspx?selected=2137
You have given your contractor 10 days to reply. Hopefully you worded the letter in such a way that failure to reply within the period would signal agreement? Hopefully you sent it recorded delivery? And you discharged his services in writing stating the reasons? I agree with Oz, spend £100 max and get a lawyer to give it the once over.
It wasn't sent recorded as his house is 5 minutes walk from mine, so was hand delivered.
Noted about lawyer once over.
It is worded that if there is no response that it would signal acceptance to the offer, and the matter is finalized.
I do find it strange that after the threat of taking me to small claims court, I have heard no more from him.
Reply to Not paying for a job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
