- Messages
- 272
I need to solvent weld a tee into a 40mm waste pipe. The pipe has been painted with what looks like gloss paint. If I sand this off, will I be able to successfully s/weld the tee on?
Thanks for any advice.
Discuss OK To Solvent Weld Fitting On Painted Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks for your reply. I'll give it a go.
Does it have to be Isopropyl, or will white spirit do?
Do you not use cleaning fluid B4 gluing plastic pipe
No the OP.Me ?
Reply to OK To Solvent Weld Fitting On Painted Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
