Discuss Old combi is dead - need recommendations for a system boiler and unvented tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all,
Our old Worcester Bosch combo is in its death throws. Its been on the cards for a while now but the time is now near.
Lots of going on in the house now so need to replace with a system boiler and unvented tank.
Been quoted by a local chap for a Baxi Megaflo 24HE and a Jet 170L tank. Its quite a bit more work than a straight swap but anyway, we had a bad experience with a Baxi many years ago and so the thought of a new one is a little scary.
I realise these things are probably much of a muchness these days but I wondered what the current thinking is on which brands / models are well respected and which are to be avoided.
Local chap thinks the warrantee on parts Baxi provides is worth having over cheaper models with expensive parts as well as over expensive models with expensive parts.
What do you all think?
Cheers
Everybody on here has their own preferences and you will get several opinions.
Personally I would fit a viessmann 200 with weather compensation and a viessmann cylinder , its what I have in my own house and if I moved tomorrow I would take it with me lol
Agree with the above and I wouldn't think 170l is enough
Viessmann, Valiant & ATAG use stainless steel heat exchangers throughout their condensing boiler ranges.
Ideal Vogues come with a 10 year gaurantee if fitted with their system filter.
Very clever interface on the Gen 2 Vogues now, clever boilers.
Sorry to go off topic... but can any of the GSR members shine abit of light on when i can view the GSR side of the forum. I am a GSR Engineer.
Thanks.
Send us a pm with your gas safe number
Reply to Old combi is dead - need recommendations for a system boiler and unvented tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years old now and was amazing when it was first installed. Around a year ago we had a problem with water dripping from the overflow pipe outside and we ended...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions about this below. I had intended to reuse the cold water tank and the cylinder sitting underneath it but my plumber suggested I replace the cylinder as...
Hi, We have a Kinetico 2020c HE Water Softener, fitted in 2008 in our loft to the cold water tank in a vented system with a conventional boiler. All good, was working fine. Recently our old Potterton Suprima conventional boiler packed up and we decided to change to a Vaillant EcoTec COMBI...
1K
