Discuss Old Flow & Return pipes capped off could this be an issue? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Raunce
    Raunce New Member
    Hi all, just moved house and while up in the loft I noticed the old 22mm Flow and Retun pipes that fed the old boiler in the loft have been capped off with push-fit stop ends. The new boiler is located in the garage at ground floor level. Please see attached diagram.[​IMG]
    I suppose at the end of the day it is just like a radiator that's been capped off. My concern was with the capped off ends being higher than the rest of the system and the possibility of an air lock making the system run less efficient. Does anyone think this is an issue? Would it be better to join the Flow and Return pipes in attic? TIA.
  2. Raunce
    Raunce New Member
  3. ShaunCorbs
    TBH it wouldn't harm to put two manual air vents up there
    • Agree Agree x 4
    • Like Like x 1
  4. Raunce
    Raunce New Member
    Thanks Shaun. Any particular ones you'd recommend?
  5. ShaunCorbs
    TBH any manual ones will be fine
    • Like Like x 1
  6. Best
    Best Trusted Plumber
    You do not join the flow and return together!
    That would create an easy circuit for no reason, and wasting heat.
    • Like Like x 1
    • Agree Agree x 1
Loading...
Similar Threads - Flow Return pipes Forum Date
Flow and return in airing cupboard. Central Heating Forum Apr 10, 2018
Best way to measure flow & return temperature's at radiators? Central Heating Forum Mar 15, 2018
