Discuss Old Honeywell 4200 3879 001 Room Stat Replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Room stat needs replacing as only clicks in above 25
T'is as old as yonder hills.
What could I replace this stat with?!
Thank you!
Honeywell 6360b
Replaced with 6360B but now the stat overrides the programmer... ie. the boiler does not respond to the programmer, is always on and only goes off when wall stat allows.:eek: Please advise! o_O:)
It's exactly the same one as you've replaced so either you've messed with the wiring or you have a very old system
Prog controls boiler and gravity hot water and room stat controls pump
seems to have sorted itself now... hmmm. There's gremlins in that there system. Checked wiring.. it may be the programmer needs replacing if it pops up again.
Reply to Old Honeywell 4200 3879 001 Room Stat Replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
