Discuss Ongoing Overflow Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I am seeking help on an ongoing overflow issue I have. I'll give as much information as I can based on my limited knowledge of systems. Our system has the hot water cylinder in the airing cupboard, and is fed by a large water storage/feeder tank above it. Our cold water is fed directly from the mains water supply although we do have a smaller water storage tank alongside the large one but I'm not sure what this does- and the leak is not coming from here.
The overflow pipe from the hot water feeder tank starts leaking every year when we start to use the central heating; everyone constantly tells me that this is the ballcock valve which I disagree with as we have no issues from March-September when we don't use the central heating system. The common trigger here is when we start to use the central heating with regularity. Is there a way that the hot water cylinder can be 'backflowing' the storage tank causing this to overflow? The water that leaks is cold but it definitely comes out of the white plastic overflow pipe which feeds out of the larger tank that provides our hot water.
I'm at a bit of a loss, as we have changed the ballcock valve on many occasions due to advice we've been given but I am absolutely convinced this is not the cause.
Thanks in advance,
Mark
Is there a dripp from the pipe that goes above your plastic tank and drops back into said tank
Your other little one is for the heating (to fill and vent)
And any chance of a few pics of the tanks and airing cupboard
Hello, I have attached the images for you.
There is no drip back into the feeder tank; the top of it is covered.
Rgds,
Mark
I'd check a few things;
Is the overflow hole in the tank too low, does it allow for expansion of the system when its is heated.
Is the cylinder thermostat faulty, causing the hot water to be excessively hot.
Is the 2 port or 3 port valve working correctly, does it shut off after the hot water demand is satisfied.
My guess would be the system is excessively hot, it expands, the water level rises and flows out of the possibly low overflow connection in the tank.
One rare possibility is back flow across the hot and cold pipes causing the tank to fill from its cold water outlet.
Is the water level in the large storage tank normally very close to bottom of overflow outlet?
Also, - Is the vent pipe (that comes from the top of copper cylinder and up into loft) a lot higher above the cold storage tank, before it drops down to well above water level?
Reply to Ongoing Overflow Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot water to our plastic header tank in the loft every time we turned the heating on. We first noticed an issue with a leak in our bedroom ceiling which we...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
Hi all, Just recently noticed the overflow has started pouring water out, there are three tanks in the loft and I'm quite sure this is from the heating. We have two boilers, one for water and one for the heating, it's an 8 bed Victorian house (bed and breakfast) I went into the loft to see what...
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs toilet which is next door. We have moved the washing machine as we are having floor tiles put down and have noticed that the waste pipe is full of dark...
