Discuss OSO unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have customer with a 330 litre OSO Invented cylinder with water coming from the cold water expansion valve.
My question is these cylinders have an internal expansion “bubble” , can they fail ?
Tried draining it and refilling to recharge the bubble
Checked hot ware temp and it’s at 60 so not over heating
Question is about the internal expansion bubble
The relief valves are notorious for passing once they have discharged,you could have recharged the bubble correctly just the valve has not reseated
Reply to OSO unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone worked to the txn150pterp kingspan unvented cylinders? They have an internal expansion bubble like the megaflows I believe. To repressurise the internal expansion bubble am I correct in saying turn the power off to the immersion/heating turn water off. Then open lowest tap to drain...
Do most composite valves now for unvented cylinders have a tee on them For the expansion valve connection? The ones I used to fit just had the balanced cold connection coming of it. Them I tee'd off downstream of the composite valve for the expansion
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
I need to change my shower mixer and I have a unvented hot water cylinder. Is it sufficient to turn off the mains? Do I need to drain the cylinder? Thanks
W
Hi all. So I have an OSO Super SXD 180 immersion heater and it is pouring a huge amount of water out of the cold water pressure relief valve regardless of whether the tank is heating or not. We're talking litres a minute currently. I have replaced the valve which changed nothing. I have...
