Discuss Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
marsaday
I am trying to find an outside tap on tool station, but cant seem to find what i need. It needs a back plate so it can be secured to the wall. Also do they come in solder, push fit or compression ?
Any links will be appreciated.
They come in all types..
Tap
15mm x ½" Outside Tap with Check Valve | NoLinkingToThis
wwall plate
Wall Plate Elbow 15mm x ½" | NoLinkingToThis
Use these compression will be easier and easier to maintain
like these? 45259.jpg 95844.jpg items 74070 and95844 at toolstation
You can also try screwfix part nos 37241-92934 and you might like to look at 82202 i find these quite useful
Don't forget you'll need to fit a double check valve inside the property to comply with the water regulations.
I quite like to use 33291 from toolstation.
Very tidy on the outside.
I like these as well, really tidy! Do have to be really carefull punching the pipe through though if drilling from inside...
If you blow the face off the outside finish it is a pain to get the fixings in for the wall plate.
Taps with integral check valves are not water regs compliant for a new installation. They are only suitable when upgrading an existing tap. A new installation must have a double check valve and isolating valve internally.
I'm fairly sure speedfit do a push fit double check valve. They're normally compression anyway.
JG Speedfit do a push fit double check valve but it's way overpriced. A standard compression one is better. The bib taps with the built in DCV don't last in very cold weather, even with the tap drained, so a separate internal one is the best solution. Don't forget to fix an isolating valve so that you can turn the tap off and drain it in the winter.
Always drill from the outside so that you don't burst your wall.
and if you are using the standard back plate, fit it below the point where the pipe comes out the wall so that it can be drained in winter.
Never thought at it that way lol.... That should be in the hints and tips section! ;P
I thought the regs said should be not must. Have they changed?
whats a double check valve ?
A double check valve will prevent any stale water in a connected hosepipe or contamination from garden / pressure washer chemicals mixing with the main (drinking) water supply, from the outside tap.
As mentioned above, the integral DCVs in the bib taps are useless after a winter and it is widely known amongst plumbers. Relying on one of those is bad practice to say the least, not sure what the regs say on the matter but I do know what good plumbers say ;)
Agreed, but I was only challenging the must be inside part. Like I said the regs might have changed.
Open Question to all: How much do you charge where you are (ballpark figure) for fitting an outside tap including materials?
ballpark my friend..£300,how much do you charge.
Paragraph 15 of the water regs is the appropriate one. 15 (1) states that an adequate device must be used to prevent backflow. and 15 (5) states that a backflow prevention device is adequate for the purpose of paragraph (1) if it is in accordance with a specification approved by the regulator for the purpose of this schedule.
This specification is the Regulators' Specifications on the Prevention of Backflow which is enforceable from 1st May 2000. This specification contains the guidance on DC valves for outside taps. The advice for backflow prevention in the WRAS water regulations guide is based on this specification.
Sorry that was a reply to marsaday asking what a double-check valve is, not directly to you hence why I quoted part of his original reply!
Reply to Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
