Discuss Pan Connector problem in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Craig BALL
    Craig BALL New Member
    Hi, does anyone have any recommendations for what pan connector arrangement would be best suited for a side entry soil pipe with 3” vertical offset? The pan is an ideal Standard Della and the deep side of the pan slightly obscures the soil pipe by about 5mm. I tried a straight flexi but it fouls the wall and a 90deg flexi was better but it seems to want to pull off the pan spigot and doesn’t sit straight in the soil pipe. Many Thanks
  2. ShaunCorbs
    The issue you have is the pan is designed for rear exit or floor
    Your going to need a bent extended pan connector a piece of 110mm or the adapter then a straight pan connector
    • Like Like x 1
    • Agree Agree x 1
  3. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Its not going to be 'pretty' no matter what you do!
    • Agree Agree x 1
    • Funny Funny x 1
  4. Craig BALL
    Thanks Shaun, much appreciated. By extended do you mean the long nose connector or the flexi?
  5. Craig BALL
    Yes I am coming to that conclusion. Its a job I am doing for my mother in law. I have an ideal standard vue toilet boxed up in my spare room that I never got round to installing in my home. I think that has better access behind so may be easier to swap and install that.
    • Agree Agree x 2
  6. ShaunCorbs
    • Like Like x 1
  7. Craig BALL
  8. SimonG
    SimonG Trusted Plumber
    Either box the pan forward or dig into the wall behind the soil pipe to give you a bit more room.
    As said above though. Wrong pan for the job.
    • Like Like x 1
  9. Rob Foster
    Rob Foster Top Contributor!!
    Never ever do jobs for your mother in law I know, never get thanked if it works and battered by your beloved if it screws up , it a loose loose situation then her brothers criticise you becaus they are better than you because their sister married below her position ...aww
    • Funny Funny x 1
  10. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Just completed an amazing ensuite for mine. #shelovesme ;);):D
  11. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
  12. Craig BALL
    Made me chuckle .
    • Like Like x 1
  13. Harvest Fields
    Not completed. But will get some next time I am there mate.
    • Like Like x 3
  14. townfanjon
    Big “walk in” there pal ( i know its probably her choice ) look and last loads longer than enclosures .
    • Like Like x 1
  15. Rob Foster
    I suppose we can all now imagine your mother in law in her shower now , nice shower
Loading...
Similar Threads - Connector problem Forum Date
Connecting Flexible Tap connector to Copper pipework Valves & Taps Yesterday at 3:17 PM
Flex tap connector washers Plumbing Forum Saturday at 8:18 AM
