Discuss Permanent live feed on boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher buzzard
Been asked to change a condemned system boiler. Trouble is it's being fed from a switch live. As soon as demand is deceased the boiler loses all power. Am I right in thinking all new boilers need a permanent live?
The Boilers I install do.
Baxi don't need perm power I believe Worcester Ri series don't
Really?
That's news!
How does the pump over run work?
I don't use them any more so you may be right, I am not doubting your knowledge.
baxi doesnt require it
worcester say it ok but not the best
The timer is in the airing cupboard, on the other side of the house. Only a 3 core to it. No spare cores. I will have a look at the baxi. Are you think the ecoblue?
yes
Just fitted ideal logic+, needs permanent live but you can remove link and put on a flash timer with feed from fused switch as there’s no timer clock on it
Reply to Permanent live feed on boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
