Discuss Phantom toilet flushes.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bugsyroo
Hi all,
I wonder if anyone can help? My downstairs loo has started to flush itself 3 or 4 times after each flush. It's obviously overflowing and them somehow rectifying itself but I can't work out how or why this is happening. I've attached a few pics of the inside of the inside of the cistern in case anyone has any ideas of what I should do to troubleshoot.
Many thanks in advance!
Bugsy
Water level looks around 10mm high, start with adjusting the part in photo number1 to bring it down to the casting mark in the cistern.
Hi Rpm,
Many thanks for your response. I have just lowered the white float bit in pic 1 by screwing the grey bit (!). Once flushed the water starts to refill the cistern lifting the white float. When the float can go no higher the water continues to fill the cistern (from the bottom I believe) until a "phantom" flush is triggered because the water level is too high.
Lowering the white bit caused the flushes to seemingly go on indefinitely. Once I screwed it back to its original position it eventually stopped.
Hope that makes sense.
Cheers,
Bugsy
Lets see if anyone can suggest a repair kit or how-to-clean solution.
Fingers crossed! Unfortunately, since fiddling the cistern has been constantly filling and therefore flushing. I have had to turn off the flow to the downstairs loo and declare it "out of bounds!"
I fear that this might not be an issue I can rectify myself and will have to get a man in!
Hi Gasman,
Thanks for getting back to me. Would fitting a new inlet valve be something be something that I could tackle myself? - I'm a pretty confident DIYer (although not as young as I used to be!). If so, would you be able to point me in the direction of the appropriate part?
As ever, thanks for your help
Bugsy
You can repair inlet valve, if you're not to good with the DIY, you can change just the washer to the valve:
http://www.NoLinkingToThis/p/arctic-products-siamp-diaphragm-washer/5006j
5 min job, worth a shot!
Brilliant! Thank you Thereisawizza. I assume the valve is located under the white bit with the grey screw? (sorry for my amateur description!). Would you be able to advise how this would be attached and therefore removed?!
Many thanks
Bugsy
take big white nut off after isolating water supply.
theres a black washer behind that needs changing, or buy identical and change whole top section is easyist to do if not sure.
those valves are rubbish, sometimes its the plastic arm at fault and hard to detect!
Hi Redsaw,
Thanks everso much for your advice. That certainly sounds like something I can attempt in the morning!
Thanks again,
Bugsy
if that does not work this will sort it,just make sure the float passes the syphon http://www.NoLinkingToThis/p/fluidm...tracking url&gclid=CJP5kPiTq88CFaky0wodvQ0LNQ
agree with the above and tbh these days i dont tend to change washers unless you cant change the fill valve
same link as above but with a brass tail, no chance of cross threading and better in my opinion
http://www.NoLinkingToThis/p/fluidmaster-brass-shank-bottom-entry-fill-valve/47792
depending on space but one should fit
http://www.NoLinkingToThis/p/flomasta-bottom-inlet-brass-shank-fill-valve/5527f
Gasman & Shaun,
This is great! Thank you so much for helping me out. I feel confident I can have a go at rectifying this problem now
All the best
Bugsy
Gasman & Shaun,
All the best
Bugsy
People landed on the Moon... you just have to make it happen, Bugsy.
Gasman & Shaun,
All the best
Bugsy
if you change the inlet valve,be careful you dont cross thread it,get yourself a new swivel washer to connect on,before removing the valve,isolate the supply and flush the toilet,some water will remain in the cistern,use a sponge to get it out,this way avoids making a mess
Reply to Phantom toilet flushes.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
