Discuss Pick your brain on Honeywell Multiple Heating Zones Wiring in the Plumbing Zone area at PlumbersForums.net
bashmaystor
Hello all
I am designing an 4 zone central heating system, which comprises of:
- Vaillant Ecotec Plus 637
Zone 1 - Main Unvented Direct Hot Water Cylinder 300l
Zone 2 - Garage Rads
Zone 3 - House Rads
Zone 4 - UFH manifold (Nu-Heat)
2 Channel Programmer for zones 1, 2.
1 Channel Programmer for zones 3, 4.
I will use Honeywell Programmers and room-stats.
Does anyone know if a ready made wiring diagram exists for multiple zones such as above?
What I figured out is that almost always I have to design the wiring myself and its never like for like with the provided diagrams. I am hoping that there is a simple to follow diagram for multiple zones out there.
Many thanks
Vinnie
You will need a 2 channel programmer for zone 3-4 and room stats so you can have time and tempreture control over the radiator circuit and the underfloor heating you dont want them on together treat it as 2 s plans contact honeywell technical they will advise you , i would work it off a low loss header, cheers kop.
S + plan 4 zones
Hello all
Zone 3 - House Rads
Many thanks
Vinnie
Pretty straight forward. 4 Zoned S plan like Shaun said.
KOP is right to mention the LLH too. I would want to install one of those.
Did you mean 'Indirect'?
If your really really struggling I can sort of whip a wiring diagram up
Why low loss header please advise
Any more than 3 zones it's best to fit a llh or where underfloor heating is involved
Reply to Pick your brain on Honeywell Multiple Heating Zones Wiring in the Plumbing Zone area at PlumbersForums.net
