Discuss Pipe covering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matt108
Hi all,
First post here, so be nice!
Just had a bathroom fitted and stuck with some ugly pipes that I would like to cover preferably in a chrome finish. Any ideas?
Snap on covers won't work due to elbow joint in pipe work I don't think?
Thanks in advance,
Matt
for the level of finish :uhoh2: thats not good
guess you could try chrome pain
Yes I was disappointed with that everything else is spot on.
He said chrome pipe couldn't be used due the elbow, I believe.
hes right but why not plan ahead and go straight into the valve, instead of coming out in the centre and bending into them
Just seen the 'Hansgrohe Isiflex 1.25 Metre Shower Hose' online. Smooth finish. Not sure on diameter though?
http://www.NoLinkingToThis/p/p801cp...tracking url&gclid=CJaA_M-HrNECFc0W0wodQP8N6Q
What like these hard to get ones from your local Screwfix store at little over £2 each !!! (and you get some that have a proper plated finish to match the pipe)
What a shame some don't go that little bit further for a good finish lets the rest of the work down.
Just get it repiped in Chrome tube with a couple of 15mm couplings & elbows a proper plumber will even put a kick in the pipe to bring the valve square to the wall.
Get it done right.
good idea but that will be too small
better off painting them silver/chrome tbh
tbh dont know why hes used a trv as well
Okay thanks for your help.
Any paint in particular?
any metal paint should be fine, do a test piece first to see if your happy with the colour
Very frustrating would it be much work to retrofit chrome piping for a plumber?
no
chrome couplings just above the boxing (to save messing about with that)
length of chrome pipe
the right rad valves
and two chrome elbows (or bend the pipe)
drain down and new bottle of inhb
approx
I've got to be honest I wouldn't want to look at that after a bathroom refit. There's Boxing below. Should be straight chrome valves and straight pipes into them. Maybe more upheaval but surely worth it?
Depends if got spare tiles / can get some more ?
Unfortunately the boxing below doesn't come out as far as the radiator does so a straight pipe down wouldn't work either.
Go to Brewers decorator centre and ask their advice. If you paint them it should look okay. It will look better than having chrome compression fittings.
Reply to Pipe covering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
