Discuss Pipe size for unvented cylinder and boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi I have an issue with running pipes ( the route )for a boiler and and unvented cylinder
1 can you combine bother together ( t one into the other)
2 if so what s the minimum pipe size for both ? As I have to either go over , under or dare I say through a steel .... it's in a loft Con
In that case you need to make a water slide, no going down-up-down again.
Its a lot to explain why but all I'm asking is the minimum size pipe needed I would never go up , down and up it's all to do with height of the steel I put in I have options with that ( height wise )
you can combine them but they must be able to take the full load best let your g3 and gas engy size them as there is a formula
As above^^^^ the diameter of the discharge pipe is dependent on elbows and length , no one is the same .
Boiler condensate pipe MUST be run in plastic . Boilers are fitted by qualified guys .
Reply to Pipe size for unvented cylinder and boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
