Discuss plant room or not to plant room in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Afternoon folks, wondered if I could get a take on an issue I have come across on my travels.
Customer of mine had a guy out to do some work on his pool boiler. The guy was not the usual guy and found a list of remedials as long as your arm (typically).
One that he has picked up on is surrounding the pool boiler situ. It is in a room just off the swimming pool and is literally just the boiler in there. The guy has classed this as a plant room and says that it requires hardwired co and smoke alarms in there.
Is he trying it on?
Is this a plant room?
Is there a legal requirement for co/smoke alarms in there?
Do they have to be hardwired??
To me this doesn’t even look like a commercial install so not sure if someone can point me in the right direction.
size of boiler and meter?
Don’t know mate I’ve not seen it in the flesh so to speak. I can find out
So it’s not a fail??? I can obviously see the sensible need but would this need to be hardwired and does it change if the plant room is within the house? (Just curious myself on that one)
What did he do just a service or llgsc
And no only time it would is if something is ar/id
If it's a domestic boiler then just use the battery smoke alarm
Sounds like the guy is thinking full interlock and detection
And if open flue I would want something in there as it's inside
Thanks mate that makes a lot of sense. How’s tricks??
Not bad looking forward at some time off in a week :) yourself ?
My God a holiday is what I really need but I keep getting these bloody stupid jobs land in my lap
:D not just me then
No it’s all I seem to get at the mo. That job above the bloke has been quoted over 2.4k to rectify along with replacing a flue section and adding some insulation
Flue section ??
Also get the customer to ask what reg number states it's must have hardwired co and smoke with interlock
Yeah it’s a long horizontal flue across a room and out the wall it would appear one section has been dented by an over excited cleaner and a ladder
Reply to plant room or not to plant room in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
Hi, I'm a sparky. We are installing a couple of standard S plan control systems for a couple of new domestic sized system boilers in a residential care home. We also look after the fire alarm here. The client has just had a new tanked gas supply installed on site to supply these boilers which...
1K
Hi all, came across this forum this looking for information on my sooting up kitchen type indoor Enviromax. I'm a retired electronics/maintenance engineer, (fwiw can answer questions on popular smart home thermostat systems), but I've installed many solid fuel boilers in the last 40 years for...
2K
Had to switch off an old fellas heating today as he had no fixed ventilation for warm air unit, tried to argue the benefits of letting him use it but was bashed with the letter of the 'law' by gassafe advisor. I totally get the point but when does it become ok (no a requirement) to leave an 80+...
2K
