Discuss Plastic cold water pipe distance from mains electrical cable in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is there a required distance that a plastic cold water pipe needs to be from a mains electrical cable. Is an armored cable.
Mains cold eg alk or just a cold water pipe internally?
I believe there is no proper regulation but the further the better. We do in Germany around a min of 50mm but haven't been there Plumbing for the last 5 years so perhaps changes have been made.
From a scan of 17th Edition Amdt 3 Wiring Regulations, there is no minimum clearance from a cold water pipe (regulation 528.3). For gas pipework the minimum clearances are 25mm from a cable to the pipe and 150mm from an electrical switch to the pipe.
For hot water or heating pipework the regulations state: -
'A wiring system shall not be installed in the vicinity of services which produce heat, smoke or fumes likely to be detrimental to the wiring, unless it is protected from harmful effects by shielding arranged so as not to affect the dissipation of heat from the wiring.' - Reg 528.3.1
I would still stick to the 25mm rule
Was going to put a piece of lagging around the pipe were it crosses the electrical cable to try keep a distance.
Reply to Plastic cold water pipe distance from mains electrical cable in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated house (4 bathrooms is tragic). Current set up is: A hot/cold mixer in the main ensuite which is ok as long as you don't run anything else. One electric...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
Hello I need to cross over an existing copper hot water pipe with a cold 15mm mains copper pipe. Is there a standard I need to adhere to in terms of clearance?
C
Hi All, I have the boiler above and the safety thermostat has snapped at the plastic cable right where it means the thermostat. This looks like it was originally all one part but can’t find the replacement harness and thermostat only the thermostat on its own with two electrical connections...
Deleted member 120897
