Discuss Plastic tap indices for metal taps (Ideal Standard) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Robert Tyrrell
I've just been replacing the ceramic valves in our bathroom taps and the little plastic indices have broken so I'd like to know where I can get replacements that don't cost silly money, if anyone knows a place.
I tried Ideal Standard and they want a stupid amount for two little plastic bungs.
I really don't care if the indices have red and blue on them, or even the Ideal Standard logo.
I want a load of them as well so that when I'm replacing valves for customers, I can finish the job properly.
The link is so you can see what Ideal Standard are charging.
https://fastpart-spares.co.uk/produ...LEVEL10=|LEVEL2_ALL=|LEVEL3_ALL=&ID=A963165AA
Thanks for that but they're just as expensive - ÂŁ6.53 for two bits of plastic!
They probably cost less than 1p to produce as well.
I could but:
A - it's in my house and my Wife wouldn't let me get away with that.
B - one of them has broken into a few pieces.
C - I'd like to be able to replace them properly, in the taps I repair for my customers.
Thanks for the suggestion though :)
New tap :D easier in the long run
Reply to Plastic tap indices for metal taps (Ideal Standard) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
I have gone to replace the washer in the shower taps as the shower is dripping but the washer seems to be a non-standard size. The 12mm was too long and so I went and bought a plastic one I could cut the end off but it is also slightly too wide, the 10mm doesn't fit either. It is a really old...
1K
Hi All, I have inherited a couple of leaky Ideal Standard pillar taps that are not in there current catalogue. I am trying to remove the caps to gain access to change the washers or whatever is needed but cannot find out how to. I have tried levering upwards with a sharp screwdriver and...
1K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
I'm hoping some informed soul may be able to kindly point me in the right direction. - Ideal Standards toilet, though there is no obvious indication of specific model number. Photo included, if it helps. - Upper part of flush mechanism has sheared off, per photos. To my untrained eye, what I...
2K
