Discuss pop up waste leaks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andekoch
After a while (6mths or so) the pop up wastes I have fitted seem to leak slightly and drip water into the cabinets.
What can I do to prevent this happening again. I have tried thread tape on the threads of the locating nut and even on the plastic insert that the ball (of the pop up lever) presses into but it still weeps (again after a few months of use). The fittings are all hand tight (much tighter and the pop up is very stiff to use).
thanks
I don't even fit them any more as they always seem to leak,jam or come apart.I fit the push up and down ones ,never had a call backs for them
Plumbers mait around the thread just under the hole in the waste thread always does the trick. Silicone the waste in too both on top of the washer and under the chrome around the top. Make double sure the plastic ball and its surrounding case are in the correct way round too. Hand tight plus a quater turn with the pump grips , hold the top in with some long nose pliers.
Thanks, that is pretty much what I do except I use thread tape and not plumbers mait. Cant really see how that makes the difference though.
I have the same issue apart form i fitted mine this weekend. I don't want to do it any tighter or else I feel the waste wont work with the lever or the thread/cover will break.
Any up date on this?View attachment 31025
Wrap the ball in ptfe tape (one or two turns) normally sorts it
click clack is the way to go - my local merchants no longer sell pop up type - they cause too many probs
Also make sure that the little plastic white washer that goes next to and against the ball has not cracked/disintergrated or disappeared down the drain. This sometimes happens
I has the fitting apart at the weekend and there was only one plastic part (outer) so I got hold of the inner plastic part and fitted this with a wrap of PTFE tape on the ball and both plastic parts and on the thread - if it still leaks (not at this time) I'll swap it for the push popup type.
Thank you for all your help.
This is very simple tho it took me ages to figure it! When assembling it put silicone GREASE on the ball and cups then do the cover nut up and then nip it up. The silicone allows it to move very freely, doesn't get washed away and doesn't harm the plastic. Been doing that for 6 years now and not had a single call back.
Mind you, I do change my number every two weeks... :p
Use a poly washer underneath with silicon before the nut. No leaks
Reply to pop up waste leaks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, I have just installed a pop up waste on new basin. I have siliconed the top with the washer, and the water holds inside the basin with the waste closed but when I pop it up to release the water down the drain it leaks out from the underside of the sink where the backnut nut washer are...
Hi Everyone, I recently brought a replacement Pop Up Waste from Argent K316-DL & the spec states it suits both overflow & non-overflow basins. However it has no slotted waste opening. How could this be used with sinks with an overflow hole & still prevent sink overflow? Thanks Natalie Argent...
just put a new pop up waste into my basin to find the trap does not fit correctly.. the trap fits just inside the waste thread opening and butts up against the plastic shoulder ensuring the rubber seal is pressed against the end Face of the waste. im able to screw the nut up but even when its...
Evening all. Need to fix a twist pop up waste which is leaking where the cable from the twist overflow which operates the pop up waste connects into a square box on the side of the waste. Is this just an o'ring or something? To change the overflow (whole waste contraption) I would need to have...
2K
Hi all, Desperately in need of help. Getting very annoyed with myself Replaced the click plug in my bathroom for a new Basin Slotted one along with the Thomas Dudley Basin Waste kit All relatively straightforward to put together but why is it still dripping I'm using the preexisting metal...
