Discuss Powerflush/magnacleanse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the difference is one is a pump that generates high flow rates around a system that increase the removal of corrosion/ debris (both magnetic and non magnetic) and one is a magnetic filter that can help remove only magnetic debris, best is use both together, if the system is not to bad a magnetic filter alone may be enough if the system is bad a pump is wat ya want.
Reply to Powerflush/magnacleanse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
