Discuss Pressure test on an existing system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mag71
Hi I will be replacing a leaking elbow on an existing dhw system soon, just wanted to find out if pressure testing is mandatory after repairs , and will all the taps need to be isolated . There are isolation valves from calorific flow return but can't see any in taps . I have only dealt with new installs to date so not to sure requirements of pressure testing existing system . Thanks for any input
No not normally, but if specd do it
if it just making a repair and the original system has held up fine before you begin, i would just fill up and check the fitting knowing the quickest way to drain down again before you begin to fill.
Reply to Pressure test on an existing system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
I've air tested pipework for years, typically 4 bar for 30 minutes. I've never had an issue with any pipework that has passed that test, occasionally you get a small leak from the air test typically old cap ends/scratched pipe which shows up easily on the test without having to inspect anything...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2 pump running at its 8M head to feed 21 rads with a theoretical output of 25kw at a 20C dT. A fairly old Vaillant 438 boiler is being replaced, the...
1K
