Discuss Pressure too high on boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a heatline vizo 24 boiler (which I know is the cheapest boiler around !) it is 11 years old and the pressure is constantly rising. We bleed the radiators to bring the pressure down but at the moment the pressure is rising even though the boiler is switched off due to awaiting a replacement fan. Any ideas what could be causing this and what could resolve the problem ( I know a new boiler would sort the problem !)
Yes but you need to be gas safe to be able to repair a boiler sorry to say
Filling loop left on or plate heat exchanger passing, not a good boiler to work on , I think you will see your engineer on a regular basis with this boiler unless it’s spotless on a regular service. Hope this helps
Reply to Pressure too high on boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating, the pressure rises over 2 and the error code 117 showing water pressure high After i did the bleeding and re-pressurize to 1.3 bar, the heating is...
What the easiest way to find why my boiler is losing pressure. It is about 5 years old Vaillant combi boiler, we have just had 2 vertical radiator removed and refitted for decorating and now the pressure keeps dropping approx once a week. I guess a leak under the floor is possible, or trapped...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank. I'm on well water and have a water softener and two whole house filters for my water. Three days ago I found my high pressure relief valve tripped...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains pressure. I bought it hoping I could have two showers across floors running with hot water even if it’s a short while, while avoiding an unvented...
Max Hill
M
