Discuss Primatic cylinder or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have a system boiler downstairs, cylinder tank upstairs in the bathroom with two feeds on side, one feed the other side and one on top
One of the feeds comes from a diverter valve for either hot water, heating or both
In the attic, there's a single tank
Is anyone able to say from that if the cylinder is prismatic?
Not sure if the diverter valve means its not
Having HW pressure trouble with a new mixer shower but not sure if I can use a pump or not
(images attached)
Chris
I wouldn't say so
Do you have to tanks in the loft ?
Not sure if it's big, would have to check
What's classed as big?
Pics of boiler should be in my post (hopefully)
Bigger than 1 foot square
Just cylinder in the pics could be a back boiler eg fire or a standard boiler ?
Sorry meant cylinder pics in post, and realised you said boiler... It's late lol
I believe it was a back boiler at some point, but at was replaced with a standard boiler (system, not combi)
Does big tank mean prismatic or small tank?
Ok could be a sealed system that would explain only one tank other than a pri system
I'm not aware of any expansion vessel in the house, just the plastic tank in the attic
Would a sealed system have to have one?
Could be in the boiler need a pic of the boiler to confirm
Would have said sealed system due to what looks like the old feed and vent hacksawed through to the left of the cylinder.
A
Nd they left all the scrap copper but took out the f+e tank ...
Would need a picture of the boiler yes but could well be a primatic cylinder.
A
Looks like some posts have gone dans been playing again baisi sealed boiler
Reply to Primatic cylinder or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
