Discuss Problem pipework that dosent make sense. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gary80gas
Stripping out hot and cold for new set of bathrooms and ensuite so identified hot and cold marked h and c on floor next to pipes. Shut it off and stripped all pipework out to floor level. Turned out a bit of spaghetti station pipework feeding from one side and disappearing other end of room into floor.
I ended with 2 pairs of open ended pipes either end of bathroom so fit an iso valve on each and turned water back on. Only one pipe the cold coming live, all other 3 dead no water. ??
The house has an annex working off same boiler and hot water not flowing, so I connected live cold to what I had marked as cold pipe (dead pipe at this point) back to boiler. Hot water restored in annex but still nothing in the 2 pipes either end of old bathroom. The hot to this bathroom and the annex all coming off same combi, if its running to one side of house it should be where I just capped it off?
So I have 2 of the pipes connected together looping the colds? The other two ends are dead but they were the hot pipes, remember the hot water is live in the annex off same boiler. Tracing pipework in this house is a nightmare
Dosent make sense to me, this should have been simple, can anyone spot my obvious mistake. This is giving me a headache. Help.
Have the valves properly reopened? Gates in particular can seem mysteriously shut when you think you opened them....
Thanks I know what you mean with gate valves.
I shut water off from mains 1/4 turn valve outside property. No other valves opened or shut. No other valves on hot system as far as I know. All hot and cold fed from this supply. Restoring mains should have restored everything. Hot and cold fed bath, shower and basin and then disappeared back into void. As if bathroom on a ring circuit?
Ok I can only assume that a hot combi fed pipe under mains 1- 1.5bar pressure had air locked. I tested the same dead pipe today and it was live... Still don't believe it. What else...
Reply to Problem pipework that dosent make sense. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
