Discuss Problems removing Mira Event XS shower inlet pipes in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Kenw60
    Kenw60 New Member
    Hi, Im trying to replace my Mira event thermostatic power shower but can't get the water inlet pipes free from the inlet manifold. There is a "special plastic removal tool but doesn't seem to do anything other than shred your fingers. any advice would be great thanks shower connections.JPG pipe tool.JPG
  2. kris
    kris Trusted Plumber GSR
    Remember the tool has to push the lugs down to free the pipe ken , so it would go just under the solder and push down,
    • Agree Agree x 1
  3. SimonG
    SimonG Trusted Plumber
    2 open ended spanners and a smack with a hammer. Something soft for it to land on.
    • Like Like x 1
    • Funny Funny x 1
  4. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    You think they are bad? You should try removing an Aqualisa Aqustream from its pipework.:p:D
    • Like Like x 1
  5. king of pipes
    Can be a bit tricky to get off but as above a tap with a hammer on 2 open ended spanners should get it moving make sure you have removed all the screws securing it to the wall and if replacing it fit the spacers behind the new unit. Cheers kop
  6. Jim Goodenough
    Jim Goodenough Plumber
    As above, make sure you have the water isolated 1st though.. otherwise you'll get a panic attack, run around like a looney, get soaking wet :D:D
    (no offence intended) ;)
Loading...
Similar Threads - Problems removing Mira Forum Date
Salamander ESP 100 problems Plumbing Forum Aug 22, 2018
Trouble removing plug release/ overflow cover. Plumbing Forum Sep 4, 2018
