Discuss Protectaline alkathene pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys anyone experience using this brand? I'll be using it and since the fittings are only compatable with there own pipe. I'm not sure sure what fitting the Scottish water guys are going to make the connection as there universal saddle furrule will need to be a protectaline saddle and I'm not sure how there going to make the connection. any experience appreciated!
Totally new service from the mains ?
Yeah I'll be blanking off my old supply. And replacing a new supply pipe and re routing it.
Don't be too surprised if they use alk from there's to the meter / stop tap
I was thinking that. where my new pipe goes over a single track road the depth will be 750min but I was thinking could I put my pipe inside a soil pipe to add strength or will the barrier pipe on its own will be suitable at 750min?
If it goes under a path or road I always sleeve it
Road yes path down pipe / 2" waste pipe
2" waste pipe I go for that. Also when the pipe comes through the building what would you use to sleeve it?
4" swept soil bend
Your meant to use the protectaline fittings with the green insert you bang in with a hammer.
Plasson fittings wont fit as its slightly bigger OD, Philmac fittings do fit although like i said your meant to use the fittings that come with the green insert.
Thanks. I'm laying that pipe in the ground but the water authorities will be making the connection but I'm sure they will know how to fit this particular pipe and fittings. Do you know if a sharkbit universal fitting would fit this pipe?
No it won't
BSS or drain centre can get the correct adapters if it helps
Reply to Protectaline alkathene pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
