W
WesleyS
Hi, since yesterday I have been aware of a faint knocking noise on my mains inlet. The noise occurs every few minutes and varies in loudness then it will stop for anything up to an hour or so and then it will start again. This happened all through the night when everything is off. When I run the cold tap the water pulses, this is more apparent when the toilet refills or if I run the mains fed shower (you can feel it through the shower head). I’m on direct supply with no meter and the problem doesn’t appear to be aggravated by me using any taps in the house, I also have a combi boiler so no water tank.
Any help would be great!
