Discuss Push Fit Fittings and rotating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How far can push fit fittings be rotated after being joined, i need to wallpaper behind a radiator that I don’t want too remove.
I have a pic just know were too host it.
45/90 degrees possible ?
FOUND AWAY TOO ADD THE PIC
Thanks in advance
Steve
Your refering to the radiator valve. The actual pushfit section will not be able to move on that picture. I wouldnt recommend trying to twist the valve at all, if you go to far you’ll get a lot of water coming out.
The photo link wasn’t there when I first replied.
Fitting will turn on the plastic pipe, but I would just have the rad removed
Thanks to the one plumber who did get back to me (rang 10) who I offered the job to remove and refit, he gave me some simple advice so managed to sort myself. 2 Quick Grips, 2 Planks, Folding Stool and a hammer. Job Done
Depends if you’re feeling lucky. I’ve never had a problem although as the old saying goes ‘If it ain’t leaking, don’t touch it’ :)
If you do turn it though and its John Guest fitting try to turn it clock wise with the thread, so the fitting tightens as you turn.
Reply to Push Fit Fittings and rotating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at floor level so I’d be looking to bend (90 degrees) straight away so I can get the lowest possible shower tray. Could someone advise what I could...
Hi Can anyone advise how the copper push fit connectors work? Is it a matter of just pushing in the pipe until it goes in as far as it can and are these connectors suitable for water and gas? Also I see that there is a special tool to release the connector if you get it wrong or not quite...
1K
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet spigot, so I want to install a wall-hung toilet on a frame to get some extra height. To put it where I want it though, I'll need to rotate the bottom...
Random push fit pipe with no end on near toilet ,would this be leading to anywhere shower etc think it is connected to a longer pipe headed toward shower cubicle , seems very loose when i move it ,would it be leading to shower or just lying loose from a previous connection? Before new bathroom...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat up but they are all connected via what I assume is Hep2O nothing is labled on the pipes that route behind the rad just on the flap behind the rad...
