Discuss pushfit fittings hep2o in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hi what do you use as a lubricant on hep2o fittings and where should it be applied.
thanks for your rsponses
dave
hep2o fittings have a small amount of lub on the rubber sealing ring inside so you don't need to lube them
If you do want to use Lube, Silicone Grease is the one But as has been said. They are pre lubed.
Reply to pushfit fittings hep2o in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
