Discuss Quadrant shower fit to tray . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
Ehup peeps , a customer has asked me to fit a new quadrant enclosure on to an existing tray .
I have never done it before and always like the tray and enclosure to come from the same manufacturer to ensure its fits .
Anybody done one just fitting the enclosure ??
Cheers in advance
As long as it's the same size your fine
They seem to be different curves , the one thats on at the minute fits like a right ***, so I suppose it couldnt look much worse
Never seen one with a different radius esp on a quad, should be the same the only thing that can change the radius is the length of the flat/ straight bits
More length sharper / tighter of a radius
Less length more curve
Beware town they are different mate you can get over it if you have enough adjustment in the wall trim but it wont sit equally on the tray and dont look pretty bud . cheers kop
Yer I know , thats why I dont want to risk it but floors tiled and the girl is short of reddies
Reply to Quadrant shower fit to tray . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Will any offset quadrant tray fit any same sized enclosure ? ie...are they all the same shape ? Or does each make of enclosure req a specific tray I'm getting the Toreno gold 1200x 800 (see oic),there's 100s of trays of the same size and shape
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a stone-resin shower tray, new ceramic tiles on the floor and half tiling on the walls. All the work...
Hi guys, new to this forum, was looking for advice regarding a mira flight shower tray i've just installed [diy]. After installing it, and then taking a shower, i noticed that the water was collecting at the edges and not dispersing away after a period of time. Now this tray was a replacement...
1K
Hi all, Just purchased a new low profile 1400 x 900 shower tray but the waste hole is 160mm wide, never seen one that big before but are these available to buy. Think my tray is a cooke & lewis eclipse, see attached image.. Hope someone can advise me on where to purchase a tray waste. Thanks..
Hi all I have two hairline cracks around shower tray plug waste hole. Is this a concern ? I.e let water in etc through crack ? And any fixes or do I need a new tray? I also have suspicions that the tray was fitted without a cement or mortar bed underneath to support the tray and this is...
1K
