Discuss Question about lpg gas safe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
Solutions
hmmmm
Reply to Question about lpg gas safe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed. We have a 1950s foldaway Cannon Gas Grill which is on the wall above the AEG Induction hob with 1 Gas burner. It worked very well on Natural gas. We have had the local gas co. install an LPG supply using...
Hi, I’m looking to retrain as a gas engineer and do a new entrants gas course. I’m a bit concerned by the ‘on-job’ work experience/shadowing, as some course want to charge £1500 to pair you up with a qualified engineer. Some courses don’t offer pairing and suggest you find your own engineer to...
Gas safe registered but not for LPG. Have been asked to quote for a number of LPG boilers so if I get the job will do my LPG ticket. But was wondering if pipe sizing is different for LPG than natural gas.
Outside of using a gas-safe LPG engineer, do I have to notify building control for the installation of pipework, hob and a 15kg propane bottle?
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas hob. Ive noticed that the oven supply 15mm and the hob supply is 15mm but once the cupboard is out i can see the hob supply is 10mm in the wall. Which...
