Discuss Radiator back boxes on first floor in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Matt0029
    Matt0029 GSR
    I have seen and worked with radiator back boxes on the ground floor were pipe are dropped in the middle of the rad. and through a back box and looped around to go back to the manifold. However how is it done on the first floor were pipe are coming to the back box from below? Do they go up the centre and have a elbow then a street elbow inside the back box to bring the pipes back down through the bottom off the back box? Thanks for any insight.
  2. king of pipes
    This is how i do it behind dot and dab add foil tape for protection it also helps the pipe to be found with a stud finder fit safe plates at skirting level . cheers kop
    • Agree Agree x 1
  3. Matt0029
    Matt0029 GSR
    Excellent thank you.
    • Like Like x 1
  4. scott_d
    scott_d Plumber GSR
    Ever get problems with air locks?
  5. ShaunCorbs
    Me personally I wouldn't want to do it like kop has done
    I would rather do tboe or normally and loop it behind the rad
  6. Matt0029
    Matt0029 GSR
    Thanks, what over way would you recommend?
  7. ShaunCorbs
    Come up out from the floor into the back box/ guide and loop it up and down into the rads ( like you do when you drop the feeds from above but upside down
  8. Matt0029
    Matt0029 GSR
    Thanks and that is manageable without kinking the pipes
  9. ShaunCorbs
    Yes
    If you want / need it tight you can use an elbow
  10. Matt0029
    Matt0029 GSR
    Thanks so you basically put the back box upside down with the pipes sticking out the top?
  11. ShaunCorbs
    yes and loop or use an elbow round
  12. Jones82
    Jones82 GSR
    Seems like a long run of 10mm to that rad?
    On the new builds I worked on we'd only run the last couple of meters in 10mm or the drop to the rad, use silver tape behind the pipework so it could be found and put the box just above skirting height then enter at the bottom of the box in the centre of the rad
  13. king of pipes
    6m run is the max no joints under the floors heating manifolds in a hallway cupboard, system can be pressure tested on first fix each run is one continuous length of pipe no issues with air locks not suitable for every project but worked very well on these one bed flats 5 rad systems ,which were above a shop the floors were sound proofed ,caber decked , with ply on top and wood plank vinyl flooring so it was really important not to have fittings under the floor as any failures would be so costly, no chance of screwing through the pipe when fitting the rad brackets sure there are other methods but it so easy to kink the pipe this method works for me systems now been installed for 8 months with no issues . cheers kop
  14. AWheating
    AWheating Trusted Plumber GSR
    Won't be air lock problems, just fit rad valves with drain offs on to enable full drain down of rad. Silver tape not needed unless your on a nhbc new build. If being solid plastered use some stich lagging to help stop plaster cracking.
    • Like Like x 1
  15. AWheating
    Manthorpe triangles are better than back boxes
    • Informative Informative x 1
Loading...
Similar Threads - Radiator boxes floor Forum Date
Help with sizing radiator Plumbing Forum Friday at 8:56 PM
radiator in bathroom Plumbing Forum Thursday at 10:33 AM
  1. radiator back box
