Discuss Radiator Sleeve Question in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi guys,
These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible for the 15mm nut and olive to attach to take the radiator valve. As you can see they are installed before nut and olive.
I've ordered a black towel rail and black straight valves and I am wondering if these tails come in black too or if I will have to buy the Talon clip-on jobbies? The issue with the clip-on sleeves is in the removal of the white collar.
Any tips? I've tried all kinds of Google searches and can't find these particular sleeves anywhere.
You won’t remove it easily looks like an uponor pipe support (mlcp)
Reply to Radiator Sleeve Question in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
