Discuss Rayburn oil oven and radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We've recently moved to a new house which has a Rayburn oven which also heats 11 radiators in the house.
This is probably a naive question but we know nothing about this type of system. I have a booklet which we're going through but there is no thermostat for the house and no individual thermostats on the radiators.
I would expect to be able to get these added but can you put these on a Rayburn heating system? I'm just surprised that the previous owners hadn't done this if they could so wonder why not?
Many thanks
Yes, you should be able to have TRVs (thermostatic rad valves) fitted, but would one radiator permanently with open valves probably.
Am sure you could also have a room stat fitted to control the radiator circuit. Or a wireless type
Reply to Rayburn oil oven and radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended the pipes (8mm microbore) and plumbed in the new radiator. I opened the isolation valves and filled up the radiator with no issues. I've bled every...
Hullo everyone its a while since I posted on here basically because i have had no plumbing issues however I have one now. My son recently moved into a house which has cellar within which is a radiator which is part of the central heating system. The rad looks old, rusty and horrible as does the...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
