Discuss Really loud humming sound from "main Boiler" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Happens about 20 mins after heating is turned on. attached is a video of it happening.
You require the services of a gas safe engy sorry to say
Reply to Really loud humming sound from "main Boiler" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
My recently installed Bosch is sounding like a washing machine. It started 4 days ago and goes through this cycle for 35mins twice a day. Using the shower in the morning usually kicks it off. Engineer’s coming in 2hrs but he doesn’t know what it could be from the video so I don’t have much...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water comes on all seems ok then after about 15/20 mins i started to hear a trickling noise from hw cylinder which i can also hear in the boiler. The central...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off. I've attached a short video of the sound. It isn't constant, it seems to happen within the first 10 mins of the boiler starting up, then you won't...
H
I need some help and advice with a boiler issue. We have F29 and then F29 appearing on our new boiler. This happened after few days where water was dripping from the condensation pipe. Our regular gas engineer(who installed the boiler) was not available and will be in a couple of days. The...
