Discuss Recommendations for wall scanner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
I'm planning to buy a wall scanner, that can detect copper pipes, joists and electrics.
Any recommendations would be much appreciated.
Thanks,
Jennie
The expensive Bosch one
Tbh I don't really trust any of them.
As long as the electrics are rcd protected and I know where the stop tap is.
Reply to Recommendations for wall scanner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can recommend? Maybe with some appropriate tape. The waste pipe is in the wall but was trimmed at some point (unnecessarily) to only 10mm extruding from...
Looking for silicone recommendations for sealing between a metal bath and upvc wall panels. I was going for dow 785+ but someone mentioned its no good for binding to plastic and that 785n would be better. Can anyone confirm this?
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a 32mm waste and two 15mm copper pipes. There is no option to box the pipes in whatsoever due to space. I’m looking to fill the cavity with foam rather...
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid? Thanks
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and wall at the bottom on inside , can’t spot any leakages here. It runs down the wall downstairs beneath shower in lines , when water is sprayed at the...
