Discuss Refilleable blow torch connector ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi peeps,
Just a quick question, where’s the best place to get a blow torch connector that’s fits in my Rothenberger and a refillable bottle ??
Cheers
Do you mean the adapter that has threads one end for into a Roth SF torch and the other end for a gas hose to push over and clamped?
You should be able to order it from a plumbing merchant who does Rothenberger, or online.
I have one myself, but just use now the single use direct screw on gas bottles
I think he is after the adaptor for refilling a Blowlamp gas cylinder from the standard LPG cylinders
Hi peeps,
Cheers
By 'Rothenberger' I assume you mean the Super fire 2 Blowtorch
and 'refillable bottle' I assume you mean the Primus 2000 Cylinder
In that case you'll need the adapter:
Part No. 3.5653
You can find it here:
Rothenberger Primus 2000 brass torch adaptor | Wolseley
Reply to Refilleable blow torch connector ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey, I've got a leaking toilet and I need to replace the filling valve device which is a Geberit 810.L3 Type 340 with a 1/2" connector. Problem I've got is the connection under the tank (image attached). The top plastic nut (yellow) is only to hold the fill valve in place - I can undo it by...
Hi folks Really daft question here but what tap connectors are you all using? I’ve picked up a couple of end feed with fibre washers today and the washers didn’t fit. Just would not fit over the little spigot that sits just inside the tap. I ended up using different washers which were baggy...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression: https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294 If not, please could someone let me know...
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build boxing to be able to fit the toilet to the wall (this will hold the concealed cistern). I bought a flexi 90deg pan connector for back-to-wall...
1K
Deleted member 120897
Hi, my wife decided she wanted new modern bathtaps instead of the old 'supertaps' we've had since we bought the place. So we bought the new taps and I tried fitting them yesterday but the new taps don't have the same fitting length as the old ones, this wasn't aproblem on the hot supply as...
