Discuss Remove lead pipe overflow in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. GC2
    GC2 New Member
    How do I go about removing the lead pipe from this cast iron bath overflow? Nothing seems keen to move!
  2. ShaunCorbs
    Do you need the pipe afterwards?
  3. GC2
    GC2 New Member
    Nope. I wouldn't mind keeping the guard but that's not essential.
  4. ShaunCorbs
    Use an angle grinder to grind the back off
    Good luck with the taps
  5. GC2
    GC2 New Member
    Thanks,
    I'm keeping the taps and hopefully just fitting adapters.
    Is there anyway of doing it without an angle grinder?
  6. ShaunCorbs
    Two ways hacksaw but very time consuming
    Or alot of heat on the back of the fitting (where the flats / nut shape is) e.g. Blow torch
    And undo from the front the front grill has female threads in it
    • Like Like x 1
  7. Christopher buzzard
    Christopher buzzard GSR
    It tends to be the putty used to seal it which causes it to be mega tight to undo. Like above. When I come across this situation I use a little heat and undo from the front. Always worked for me. Good luck.
  8. GC2
    GC2 New Member
    Might give it a go with the blow torch and if that fails angle grinder it.
    Thanks again
  9. GC2
    GC2 New Member
    Going to give this a go. What's the best tool to use to undo the grill from the front?
    Cheers
  10. ShaunCorbs
    Strap wrench but you have to be careful due to the heat
  11. ShaunCorbs
    Any luck ?
  12. GC2
    GC2 New Member
    Yes! Just in the last minute. Combination of angle grinder and drilling.
    • Like Like x 1
Loading...
Similar Threads - Remove lead pipe Forum Date
How difficult is it to remove this?! Plumbing Forum Wednesday at 1:07 PM
Have my recent threads been removed? Plumbers Arms Jan 23, 2018
