Discuss Remove shower plate and cartridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
JT5
Can anyone advise how to remove this plate and get to the cartridge? I need to replace it. Will likely get a plumber to do the work, but they all say they need to know the brand and model first, and there's nothing on the shower or plate that advises of this.
The ring on the thermostat part just keeps spinning, so it doesn't seem like it unscrews.
Many thanks in advance!
Might be just suck on
Thin hacksaw blade all the way round
Sounds like another one for the showerdoc.co.uk
Or is it .com?
Definitely wouldn't suck on it
Good advice, but too late - didn't taste good. Will check out showerdoc - cheers!
  • Funny
Reactions: rpm
Another cheap Chinese mixer bites the dust!
Might be a good idea for any that are fitted, to stick a bit of paper in there before the trim goes on with some details of manufacturer, or where it was purchased.
Take off both handles. The lower ring will turn and the plate will come off.
Reply to Remove shower plate and cartridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This is driving me bonkers! I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early Florentine model circa 2006 though not 100% sure. I've removed the faceplate, unscrewed the chrome collar - and now want to extract the diverter...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
A
I'm replacing the shower cartridge on my Bristan 1901 Thermostatic Exposed Dual Control Shower (Top Outlet). I have removed the cap and screw but the temperature handle won't come off. Am I missing something or does it just need more force?
AlexTTT
A
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
Hi, I have a Hansgrohe T30 thermostatic cartridge (98282000) that I need to clean or replace, but I can't remove it. I've spent ages Googling this, but I just can't find the right tool to help - it's probably a custom Hansgrohe tool. Can anyone guide me? Thanks!
