Discuss Removing a boiler from wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
southcoastboile
just wondered if anyone has any tips on removing a wall hung boiler in an alkward place. We have to lean right over the kitchen units into the corner to be able to get the old one off the wall so putting something under it and dropping the boiler down slowly then sliding it across the worktop would probably be easier because you can't get right under it to lift it up very easily.
Is there anything that you can buy specifically for removing a boiler like that that stops the work surface from getting scratched or something?
Not that I have seen. I normally have to remove the cupboards if the kitchen is new. Just make sure you cost in the time it will take.
I normally put a piece of 18mm ply if I need to drop it quick but I haven't met a boiler that I can't rangle
Reply to Removing a boiler from wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi. I moved in to a new build home and 3 years later (after the builders warranty expires) the boiler is slipping off the wall at one side. This is putting pressure on the flue. Not something I’m happy with. Does anyone know the guidelines on how they should be fitted? I want to prove they...
Hi I need to pull out a drawer base unit from my bathroom, not fitted by me. I have removed most screws but I am faced with one of these in each top corner inside the unit, which I belive are called wall bracket hangers. There is screw as pictured, then another single screw underneath. The...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
Hi An idiot Bathroom fitter has cut down a soil pipe and fitted an AAV valve, then placed a built in bathroom cabinet with the soil pipe in the corner unit making the only easy way to access anywhere near the soil pipe by reaching up from where the kicker board goes. You can see from the photo...
1K
