Discuss Replace an old garden tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
John mccreesh
Hi, I have a very old garden tap that leaks and needs replacing. Any advice or ideas greatly appreciated. Thanks.
That's going to be difficult
Honest opinion best employe the services of a plumber
Hello John. The tap itself probably can be carefully repaired but the pipe is lead and only thing to do with lead pipe us to have it replaced to some extent, if not completely.
Ideally you are better with the pipe supply coming from indoors to outside so as not to have ugly exposed pipes that can also freeze. But if nothing much can be done, then just an adapter fitting from lead to 15mm pipe and a brass tap back plate and new tap needed.
As Shaun said, - get a plumber to look at it to decide
Thanks for the help, will get a couple of quotes from plumbers.
yes, usually easy to service the tap, but probably hasn't got a double check valve, in which case should not be using a hose on it.
Reply to Replace an old garden tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I've attached an image of an old garden tap with a new garden tap replacement, except the thread on the new tap is larger than the existing tap fitting. Is there a reducing nut that can adapt the new tap to the wall fitting or could the new tap handle be used to replace the old handle and...
I need a quote to replace a soil stack ( cast ) in Leyton e10. The stack is already in plastic at the bottom. There also needs to be amendment to branch to accomodate a change of position of the bathroom in the upstairs flat. BTW - this is one up/ one down flat arrangment. There is access to...
Have a sink basin tap photo attached and need to replace the heads as behind they have cracked. Any idea where I can get replacement tap head covers only need to change the tap head covers really Problem is the old tap head covers wont turn! Any ideas please? Thanks
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and the compression joint where the pipe enters an isolation valve now leaks. The outside tap was covered for the winter by an insulating blanket. I...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
