Discuss Replacing a 2 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone tell me if the thread size on a Honeywell 3/4 imperial valve is compatible with a 22mm valve.
no different threads
sorry
Always a pain but use olive removal tool and on with the new ones . The older imperial threads are alot closer together.
As above remove the old olives these can be replaced with 3/4 imperial olives from most suppliers, use the new valve nuts the 3/4 olives disgard the 22mm ones a small amout of pipe sealant fit and wire the valve then your good to go cheers kop
I was afraid that might be the case, I will be using a freezing kit so thanks for the advice. Why manufactures go to the expense of re-tooling is beyond me.
Reply to Replacing a 2 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
