Discuss Replacing a Triton Enlight 2 in the New Member Introductions area at UKPlumbersForums.co.uk.
Thread Status:
  1. Matt
    Matt New Member
    Hi I'm an electrician more use to testing power to showers then replacing them. My Enlight 2 has stopped working after 3 years it is now only hot when on 10 so assume 1 of the elements have gone. Shower is mounted on water proof shower board I want to use existing cut outs. Looks like Enlight is no longer sold. Can any one recommend shower that will easily replace it or should I just change parts? Cheers for any advise.
  2. Sedgy40
    Sedgy40 Member
    Triton do spare parts pal
  3. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Where are the electric and water connectors on the shower. Can you take a picture?
  4. moonlight
    moonlight Plumber GSR
    It will depend on your shower footprint. If you still want a Triton T80Z has multi entry points for wiring and plumbing.
  5. goerge
    goerge New Member
    Often cheaper to replace the shower than get spare parts Screwfix have some great triton shower prices.
  6. Matt
    Matt New Member
    I have seen they do an 8.5Kwand 9.5Kw replacement for about £50 which I think was the cost of the shower I am considering this if a replacement shower won't fit the holes in the shower board. Thank you
  7. Matt
    Matt New Member
    I have attached thanks for the reply
  8. Matt
    Matt New Member
    That is my thought but also weighing up maintaining the integrity of the board behind it so would like to find something that fits the existing holes. Cheers
  9. moonlight
    As long as the new footprint is roughly the same size. You could silicone the other holes if not exact. Don't forget you already have holes for the wire and supply.
  10. moonlight
    The pictures you posted look like the Mira jump.
  11. Matt
    Matt New Member
    Thank you just looked at the PDFs for the Mira Jump and looks like the holes for water inlet and electrical supply I currently have should match perfectly.
    • Like Like x 1
  12. Harvest Fields
    All good then.;)
  13. Matt
    Matt New Member
    I think I will either fit a Mira Jump or change the element. Not much difference in price. which is the easier of the 2 jobs. might be naive as haven't done either before but I think I am capable any pitfalls to watch out for. Obviously isolate supply and water and give it a go cross my fingers.
  14. moonlight
    Difference being new guarantee with new shower
    • Like Like x 1
Loading...
Similar Threads - Replacing Triton Enlight Forum Date
When replacing silicone.. Bathrooms, Showers and Wetrooms Apr 10, 2018
Combimate leaking after replacing crystals Plumbing Forum Mar 15, 2018
Thread Status:
  1. triton enlight
  1. triton enlight
