Discuss Replacing a UFH blending valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
have to replace this valve today for an UFH circuit.
Question: what is the flow mixed with to reduce the temp?
Is it literally just flow and return pipes?
Yes very crude way of doing it by using a tmv2/3 but it works
Yeah I've not seen it done like that before.. I kinda knew it was flow/return pipes but just wanted to double check.
Cheers guys
Reply to Replacing a UFH blending valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below I think is similar to the TIO Mixing unit. In the unit below, the hot (boiler) water enters from the bottom left, red arrow, up through the "mixing...
Hi all. I've currently got a system boiler with cylinder and rads on s-plan. I'm planning on installing UFH in my kitchen/diner and utility/downstairs loo. My question is around mixing valves and opentherm. Do mixing valves dynamically adjust the amount of cold being mixed in response to the...
I need to replace a 3/4 or 22mm blending valve on a Telford Trident electric hot water boiler. see attached picture of the original part. Telford asked me 100£ for the part and refused to provide the technical details. I am pretty confident this is not a proprietary part and similar parts...
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and replaced it with new components from Nu-Heat but the valve is not working properly. The valve replacement seems very simple with 4 main components and some...
Two loop UFH system heating 24M2 with lots of glass. Loop lenghts 90M each X 16MM OD piping UFH output 9.52kw. flow/return 55C/34C, dT 21C fowrates, 3.0LPM & 3.5LPM = 6.5LPM total Boiler Vaillant Ecotec plus 438. flow/return 65C/59C due to high recirc rate required to get the boiler away at...
