Discuss Replacing cloakroom toilet suite - help with fittings needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys
I'm replacing an old toilet cloakroom suite with new vanity basin unit and vanity toilet unit. Current fittings date back to early 1980s.
As a DIYer I'm thinking I should replace the isolating valve for the toilet inlet with a straight coupler and place a new isolating valve further up so I have decent access in future. (Photo attached).
1. Do you guys think this is the right thing to do?
2. What valves and pipes would people suggest? I.e. copper or plastic / push fit or compression?
3. Do I need to replace the swan neck pan connector?
Craig
Hi Craig,
1. Yes it would certainly be beneficial in the future to cut out that old iso and locate a new one higher up the pipe.
2, We prefer to use copper and solder fittings, but if you are a not that experienced or confident then use the push fit fittings like speed fit for ease. you will need a 15mm straight coupler to connect to the existing pipe under the floor, A 15 mm chrome compression ball a fix (iso valve) and a 1/2"-15mm tap connector to fit the new toilet inlet valve also 1 meter of 15mm plastic pipe. Make sure you use reinforcing pipe inserts on the pipes at all the fitting joints. And take out that old rusty nail and use a hinged plastic 15mm pipe clip screwed to the joist to support the pipe.
3, Definitely replace the swan neck pan connector. never re-use an old one. You will regret it.
Agree 100% with Darren , couldnt have put it better myself lol
Reply to Replacing cloakroom toilet suite - help with fittings needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the night so I fitted a simple pull cord swith to turn it off at night About a month ago I recently had a blockage so pulled it apart and cleaned everything...
O
im a DIYer remodeling my master bath. long story short, after tiling my toilet flange is too high. im aware of all of the options to repair, but we could use a new toilet anyway..so my question is, is there a toilet made that will fit a high flange? or do I need to just suck it up and repair it?
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hi, I'm in the process of buying the fittings for my new bathroom and I'm trying to find a combo toilet/ vanity unit. The one i'm looking for is the darky navy one the second image on the gallery on mabathrooms .co.uk . I spoke to the guy who owns ma bathrooms and he said that the customer...
Hi Guys I am at the design stage of having a En-Suite built and have an issue that I cannot seem to resolve. For long and complex reasons I have to have a macerator and that needs to sit behind a close coupled toilet. this will take the waste from a sink, shower and toilet. Saniflow say I need...
1K
